Fractional Filters: An Optimization Approach
The design and optimization of fractional filters is
considered in this paper. Some of the classic filter architectures are
presented and their performances relatively to an ideal amplitude
spectrum evaluated. The fractional filters are designed using the
differential evolution optimization algorithm for computing their
parameters. To evaluate the performances of all the filters the
quadratic error between the computed amplitude is calculated against an
ideal (goal) response. The fractional filters have a better behavior,
both in the pass and reject-band.
Bibliothèque électronique [cs.DL]
