Controlled Invariant Polyhedral Sets for Constrained Discrete-Time Descriptor Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper addresses the problem of constructing controlled invariant polyhedral sets for linear discrete-time descriptor systems subject to state and control constraints and persistent disturbances. Regardless the large number of contributions on set invariance for linear systems in the standard form, there are few works dealing with set invariance properties in the case of descriptor systems. Here, assuming regularity and causality of the descriptor system, the state equations are written in such way that standard algorithms can be directly applied. Moreover, state and control constraints can be enforced through a piecewise linear delayed state feedback. A numerical example is presented to illustrate these ideas.
AraujoD10.pdf (130.45 Ko) Télécharger le fichier
hal-01060762 , version 1 (16-11-2017)
Paternité
José Mario Araújo, Carlos Eduardo Trabuco Dórea. Controlled Invariant Polyhedral Sets for Constrained Discrete-Time Descriptor Systems. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.383-390, ⟨10.1007/978-3-642-11628-5_42⟩. ⟨hal-01060762⟩
72 Consultations
89 Téléchargements
