On the Mineral and Vegetal Oils Used as Electroinsulation in Transformers - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Due to the relatively large availability and reduced price, the mineral transformer oils are widely used as electrical insulating liquids. However, mineral oil drastically degrades over time in service. New efforts were made to improve mineral oils characteristics, and other types of liquids like vegetal oils are proposed. This paper deals with new comparative tests on mineral and vegetal oils using as indicator the electric strength. The samples of non-additive mineral oil type TR 30 and vegetal oils of rape, sunflower and corn have been tested with increasing voltage of 60 Hz using different electrodes. The obtained data have been statistical processed. The analyze shows different average values of electrical strength for the different type of sample. New method of testing through electrical breakdown is proposed. Experimental data confirms that it is possible to use as electroinsulation organic vegetal oils in power transformers.
SerbanSH10.pdf (248.58 Ko) Télécharger le fichier
hal-01060768 , version 1 (23-11-2017)
Paternité
Mariana Şerban, Livia Sângeorzan, Elena Helerea. On the Mineral and Vegetal Oils Used as Electroinsulation in Transformers. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.433-440, ⟨10.1007/978-3-642-11628-5_48⟩. ⟨hal-01060768⟩
61 Consultations
44 Téléchargements
