Business and IS/IT Strategic Alignment Framework
Incorporating information systems and information
technology (IS/IT) in the organizations have considerable risks, and
these risks are increased when a strategic plan for its incorporation is
not done. The objective of this research is to contribute in the
alignment between business and IS/IT strategies using concepts and
techniques from engineering and enterprise architecture. To achieve this
objective, this research proposes to define a modeling framework for
business and IS/IT strategic alignment. The implementation of this
proposal in a ceramic tile company has helped to validate its
usefulness.
Bibliothèque électronique [cs.DL]
