Applications of Dynamic Deployment of Services in Industrial Automation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Service-oriented Architecture (SOA) is becoming a de facto paradigm for business and enterprise integration. SOA is expanding into several domains of application envisioning a unified solution suitable across all different layers of an enterprise infrastructure. The application of SOA based on open web standards can significantly enhance the interoperability and openness of those devices. By embedding a dynamical deployment service even into small field de- vices, it would be either possible to allow machine builders to place built- in services and still allow the integrator to deploy on-the-run the services that best fit his current application. This approach allows the developer to keep his own preferred development language, but still deliver a SOA- compliant application. A dynamic deployment service is envisaged as a fundamental framework to support more complex applications, reducing deployment delays, while increasing overall system agility. As use-case scenario, a dynamic deployment service was implemented over DPWS and WS-Management specifications allowing designing and programming an automation application using IEC61131 languages, and deploying these components as web services into devices.
CandidoBJC10.pdf (151.52 Ko) Télécharger le fichier
hal-01060798 , version 1 (17-11-2017)
Paternité
Gonçalo Candido, José Barata, François Jammes, Armando W. Colombo. Applications of Dynamic Deployment of Services in Industrial Automation. First IFIP WG 5.5/SOCOLNET Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2010, Costa de Caparica, Portugal. pp.149-156, ⟨10.1007/978-3-642-11628-5_16⟩. ⟨hal-01060798⟩
50 Consultations
90 Téléchargements
