Impact of Trust Management and Information Sharing to Adversarial Cost in Ranking Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ranking systems such as those in product review sites and recommender systems usually use ratings to rank favorite items based on both their quality and popularity. Since higher ranked items are more likely selected and yield more revenues for their owners, providers of unpopular and low quality items have strong incentives to strategically manipulate their ranking. This paper analyzes the adversary cost for manipulating these rankings in a variety of scenarios. Particularly, we analyze and compare the adversarial cost to attack ranking systems that use various trust measures to detect and eliminate malicious ratings to systems that use no such a trust management mechanism. We provide theoretical results showing the relation between the capability of the trust mechanism in detecting malicious ratings and the minimal adversarial cost for successfully changing the ranking. Furthermore, we study the impact of sharing trust information between ranking systems to the adversarial cost. It is proved that sharing information between two ranking systems on common user identities and malicious behaviors detected can increase considerably the minimal adversarial cost to successfully attack the two systems under certain assumptions. The numerical evaluation of our results shows that the estimated adversary cost for manipulating the item ranking can be made significant when proper trust mechanisms are employed or combined.
VuPA10.pdf (303.28 Ko) Télécharger le fichier
hal-01061323 , version 1 (24-11-2017)
Paternité
Le-Hung Vu, Thanasis G. Papaioannou, Karl Aberer. Impact of Trust Management and Information Sharing to Adversarial Cost in Ranking Systems. 4th IFIP WG 11.11 International on Trust Management (TM), Jun 2010, Morioka, Japan. pp.108-124, ⟨10.1007/978-3-642-13446-3_8⟩. ⟨hal-01061323⟩
41 Consultations
51 Téléchargements
