Collective Mind, Part II: technical report - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2013
Nowadays, engineers have to develop software often without even knowing which hardware it will eventually run on in numerous mobile phones, tablets, laptops, data centers, supercomputers and cloud services. Unfortunately, optimizing compilers often fail to produce fast and energy efficient code across all hardware configurations. In this technical report, we present the first to our knowledge practical, collaborative, publicly available and Wikipedia-inspired solution to this problem based on our recent Collective Mind Infrastructure and Repository.
article.pdf (3.64 Mo) Télécharger le fichier
hal-01066126 , version 1 (19-09-2014)
  • HAL Id : hal-01066126 , version 1
Grigori Fursin. Collective Mind, Part II: technical report. 2013. ⟨hal-01066126⟩
175 Consultations
124 Téléchargements
