Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
Reports
Optimization of an Unsteady System Governed by PDEs using a Multi-Objective Descent Method
Camilla Fiorini 1 Régis Duvigneau 1 Jean-Antoine Désidéri 1
1 OPALE - Optimization and control, numerical algorithms and integration of complex multidiscipline systems governed by PDE
CRISAM - Inria Sophia Antipolis - Méditerranée , JAD - Laboratoire Jean Alexandre Dieudonné : UMR6621
Abstract : The aim of this work is to develop an approach to solve optimization problems in which the functional that has to be minimized is time dependent. In the literature, the most common approach when dealing with unsteady problems, is to consider a time-average criterion. However, this approach is limited since the dynamical nature of the state is neglected. These considerations lead to the alternative idea of building a set of cost functionals by evaluating a single criterion at different sampling times. In this way, the optimization of the unsteady system is defined as a multi-objective optimization problem, that will be solved using an appropriate descent algorithm. Moreover, we also consider a hybrid approach, for which the set of cost functionals is built by doing a time-average operation over multiple intervals. These strategies are illustrated and applied to a non-linear unsteady system governed by a one-dimensional convection-diffusion-reaction partial differential equation.
Document type :
Reports
Complete list of metadata
https://hal.inria.fr/hal-01068309
Contributor : Régis Duvigneau Connect in order to contact the contributor
Submitted on : Thursday, September 25, 2014 - 2:05:26 PM
Last modification on : Saturday, June 25, 2022 - 11:14:45 PM
Long-term archiving on: : Friday, April 14, 2017 - 1:50:19 PM
File
RR-8603.pdf
Identifiers
  • HAL Id : hal-01068309, version 1
Citation
Camilla Fiorini, Régis Duvigneau, Jean-Antoine Désidéri. Optimization of an Unsteady System Governed by PDEs using a Multi-Objective Descent Method. [Research Report] RR-8603, INRIA. 2014. ⟨hal-01068309⟩
Share
Metrics
Record views
292
Files downloads
508
