CGALmesh: a Generic Framework for Delaunay Mesh Generation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Mathematical Software Année : 2015
Pierre Alliez
Mariette Yvinec
Jean-Daniel Boissonnat
  • Fonction : Auteur
  • PersonId : 830857
CGALmesh is the mesh generation software package of the Computational Geometry Algorithm Library (CGAL). It generates isotropic simplicial meshes -- surface triangular meshes or volume tetrahedral meshes -- from input surfaces, 3D domains as well as 3D multi-domains, with or without sharp features. The underlying meshing algorithm relies on restricted Delaunay triangulations to approximate domains and surfaces, and on Delaunay refinement to ensure both approximation accuracy and mesh quality. CGALmesh provides guarantees on approximation quality as well as on the size and shape of the mesh elements. It provides four optional mesh optimization algorithms to further improve the mesh quality. A distinctive property of CGALmesh is its high flexibility with respect to the input domain representation. Such a flexibility is achieved through a careful software design, gathering into a single abstract concept, denoted by the oracle, all required interface features between the meshing engine and the input domain. We already provide oracles for domains defined by polyhedral and implicit surfaces.
cgalmesh.pdf (11.76 Mo) Télécharger le fichier
hal-01071759 , version 1 (06-10-2014)
Clément Jamin, Pierre Alliez, Mariette Yvinec, Jean-Daniel Boissonnat. CGALmesh: a Generic Framework for Delaunay Mesh Generation. ACM Transactions on Mathematical Software, 2015, 41 (4), pp.24. ⟨10.1145/2699463⟩. ⟨hal-01071759⟩
1015 Consultations
925 Téléchargements
