Experimental Analysis and Characterization of a Wireless Sensor Network Environment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Bogdan Pavkovic
  • Fonction : Auteur
Fabrice Theoleyre
Andrzej Duda
Existing testbeds, even though rare and specialized, are not used to their full potential. Collected data during an experimentation is just used to evaluate some specific tested aspect. To further benefit from the knowledge gathered on a testbed and to obtain the insight into the WSN environment itself, we propose a thorough statistical analysis. Some of our analysis include radio link characterization, its correlation with environmental parameters as well as an insight into network dynamics from the point of view of a node and a link. We also discuss how testbeds should be designed or improved to provide more detailed information necessary for an advanced analysis.
no abstract
wsn_testbed.pdf (1.33 Mo) Télécharger le fichier
hal-01073416 , version 1 (02-06-2020)
Bogdan Pavkovic, Fabrice Theoleyre, Andrzej Duda. Experimental Analysis and Characterization of a Wireless Sensor Network Environment. PE-WASUN 2010 - International Symposium on Performance Evaluation of Wireless Ad Hoc, Sensor, and Ubiquitous Networks, 2010, Bodrum, Turkey. pp.25, ⟨10.1145/1868589.1868595⟩. ⟨hal-01073416⟩
81 Consultations
104 Téléchargements
