Minimizing a real-time task set through Task Clustering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In the industry, real-time systems are specified as a set of hundreds of functionalities with timing constraints. Implementing those functionalities as threads in a one-to-one relation is not realistic due to the overhead caused by the large number of threads. In this paper, we present task clustering, which aims at minimizing the number of threads while preserving the schedulability. We prove that our clustering problem is NP-Hard and describe a heuristic to tackle it. Our approach has been applied to fixed-task or fixed-job priority based scheduling policies as Deadline Monotonic (DM) or Earliest Deadline First (EDF).
bertoutRTNS14.pdf (272.23 Ko) Télécharger le fichier
hal-01073565 , version 1 (10-10-2014)
Antoine Bertout, Julien Forget, Richard Olejnik. Minimizing a real-time task set through Task Clustering. Proceedings of the 22nd International Conference on Real-Time Networks and Systems, Oct 2014, Versailles, France. pp.23-31, ⟨10.1145/2659787.2659820⟩. ⟨hal-01073565⟩
140 Consultations
521 Téléchargements
