Towards an automatic generation of dense linear algebra solvers on parallel architectures - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
The increasing complexity of new parallel architectures has widened the gap between adaptability and efficiency of the codes. As high performance numerical libraries tend to focus more on performance, we wish to address this issue using a C++ library called NT2. By analyzing the properties of the linear algebra domain that can be extracted from numerical libraries and combining them with architectural features, we developed a generic approach to solve dense linear systems on various architectures including CPU and GPU. We have then extended our work with an example of a least squares solver based on semi-normal equations in mixed precision that cannot be found in current libraries. For the automatically generated solvers, we report performance comparison with state-of-the-art codes, showing that it is possible to obtain a generic code with a high-level interface (similar to Matlab) that can run either on CPU or GPU and that does not generate significant overhead.
RR-8615.pdf (951.25 Ko) Télécharger le fichier
hal-01075663 , version 1 (19-10-2014)
  • HAL Id : hal-01075663 , version 1
Marc Baboulin, Joel Falcou, Ian Masliah. Towards an automatic generation of dense linear algebra solvers on parallel architectures. [Research Report] RR-8615, Université Paris-Sud; INRIA. 2014, pp.20. ⟨hal-01075663⟩
414 Consultations
329 Téléchargements
