HAL will be down for maintenance from Friday, June 10 at 4pm through Monday, June 13 at 9am. More information
Reports
Reducing the complexity of the performance analysis of a multi- server facilities
Tulin Atmaca 1 Thomas Begin 2 Alexandre Brandwajn 3 Hind Castel-Taleb 1
2 DANTE - Dynamic Networks : Temporal and Structural Capture Approach
Inria Grenoble - Rhône-Alpes, LIP - Laboratoire de l'Informatique du Parallélisme, IXXI - Institut Rhône-Alpin des systèmes complexes
Abstract : Systems with multiple servers are common in many areas and their correct dimensioning is in general a difficult problem under realistic assumptions on the pattern of user arrivals and service time distribution. We present an approximate solution for the underlying Ph/Ph/c/N queueing model. Our approximation decomposes the solution of the Ph/Ph/c/N queue into solutions of simpler M/Ph/c/N and Ph/M/c/N queues. It is conceptually simple, easy to implement and produces generally accurate results for the mean number in the system, as well as the loss probability. A significant speed advantage compared to the numerical solution of the full Ph/Ph/c/N queue can be gained as the number of phases representing the arrival process and/or the number of servers increases.
Document type :
Reports
Complete list of metadata
Cited literature [14 references]  Display  Hide  Download
https://hal.inria.fr/hal-01076366
Contributor : Thomas Begin Connect in order to contact the contributor
Submitted on : Tuesday, October 21, 2014 - 8:15:01 PM
Last modification on : Thursday, April 14, 2022 - 2:48:03 PM
Long-term archiving on: : Thursday, January 22, 2015 - 11:01:00 AM
File
RR-8617.pdf
Identifiers
  • HAL Id : hal-01076366, version 1
Citation
Tulin Atmaca, Thomas Begin, Alexandre Brandwajn, Hind Castel-Taleb. Reducing the complexity of the performance analysis of a multi- server facilities. [Research Report] RR-8617, Institut Telecom, Telecom SudParis, Evry, France; Université Lyon 1 / LIP (UMR INRIA, ENS Lyon CNRS, UCBL), Lyon France; University of California Santa Cruz, Baskin School of Engineering, USA; INRIA. 2014. ⟨hal-01076366⟩
Share
Metrics
Record views
164
Files downloads
85
