Asynchronous Computing of a Discrete Voronoi Diagram on a Cellular Automaton Using 1-Norm: Application to Roadmap Extraction - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nassim Kaldé
  • Fonction : Auteur
  • PersonId : 957500
This article addresses the problem of computing a Voronoi diagram in a distributed fashion without any synchronization heuristic. To our knowledge, no previous work asynchronously solves this problem. We investigate a simple case of asynchronism and tackle this challenge in a decentralized fashion on a grid of communicating cells with a von Neumann neighborhood. We describe algorithms for extracting single site, area and pseudo line Voronoi diagrams. These algorithms are implemented and executed on maps in which we consider different kinds of sites defined as simple polygonal shapes to extract roadmaps.
Fichier non déposé
hal-01076951 , version 1 (23-10-2014)
  • HAL Id : hal-01076951 , version 1
Nassim Kaldé, Olivier Simonin, François Charpillet. Asynchronous Computing of a Discrete Voronoi Diagram on a Cellular Automaton Using 1-Norm: Application to Roadmap Extraction. IEEE International Conference on Tools with Artificial Intelligence (ICTAI), Nov 2014, Limassol, Cyprus. ⟨hal-01076951⟩
133 Consultations
0 Téléchargements
