Glutamate Mediated Astrocytic Filtering of Neuronal Activity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue PLoS Computational Biology Année : 2014
Neuron-astrocyte communication is an important regulatory mechanism in various brain functions but its complexity and role are yet to be fully understood. In particular, the temporal pattern of astrocyte response to neuronal firing has not been fully characterized. Here, we used neuron-astrocyte cultures on multi-electrode arrays coupled to Ca2+ imaging and explored the range of neuronal stimulation frequencies while keeping constant the amount of stimulation. Our results reveal that astrocytes specifically respond to the frequency of neuronal stimulation by intracellular Ca2+ transients, with a clear onset of astrocytic activation at neuron firing rates around 3-5 Hz. The cell-to-cell heterogeneity of the astrocyte Ca2+ response was however large and increasing with stimulation frequency. Astrocytic activation by neurons was abolished with antagonists of type I metabotropic glutamate receptor, validating the glutamate-dependence of this neuron-to-astrocyte pathway. Using a realistic biophysical model of glutamate-based intracellular calcium signaling in astrocytes, we suggest that the stepwise response is due to the supralinear dynamics of intracellular IP3 and that the heterogeneity of the responses may be due to the heterogeneity of the astrocyte-to-astrocyte couplings via gap junction channels. Therefore our results present astrocyte intracellular Ca2+ activity as a nonlinear integrator of glutamate- dependent neuronal activity.
Wallach_etal_Final.pdf (3.31 Mo) Télécharger le fichier
hal-01077738 , version 1 (27-10-2014)
hal-01077738 , version 2 (19-12-2014)
Gilad Wallach, Jules Lallouette, Nitzan Herzog, Maurizio de Pittà, Eshel Ben Jacob, et al.. Glutamate Mediated Astrocytic Filtering of Neuronal Activity. PLoS Computational Biology, 2014, 12 (10), e1003964 (19 p.). ⟨10.1371/journal.pcbi.1003964⟩. ⟨hal-01077738v2⟩
336 Consultations
253 Téléchargements
