Efficient learning by implicit exploration in bandit problems with side observations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Tomáš Kocák
  • Fonction : Auteur
  • PersonId : 955512
Gergely Neu
  • Fonction : Auteur
  • PersonId : 961171
Michal Valko
Rémi Munos
  • Fonction : Auteur
  • PersonId : 836863
We consider online learning problems under a a partial observability model capturing situations where the information conveyed to the learner is between full information and bandit feedback. In the simplest variant, we assume that in addition to its own loss, the learner also gets to observe losses of some other actions. The revealed losses depend on the learner's action and a directed observation system chosen by the environment. For this setting, we propose the first algorithm that enjoys near-optimal regret guarantees without having to know the observation system before selecting its actions. Along similar lines, we also define a new partial information setting that models online combinatorial optimization problems where the feedback received by the learner is between semi-bandit and full feedback. As the predictions of our first algorithm cannot be always computed efficiently in this setting, we propose another algorithm with similar properties and with the benefit of always being computationally efficient, at the price of a slightly more complicated tuning mechanism. Both algorithms rely on a novel exploration strategy called implicit exploration, which is shown to be more efficient both computationally and information-theoretically than previously studied exploration strategies for the problem.
kocak2014efficient.pdf (409.14 Ko) Télécharger le fichier
hal-01079351 , version 1 (01-11-2014)
hal-01079351 , version 2 (03-11-2014)
  • HAL Id : hal-01079351 , version 2
Tomáš Kocák, Gergely Neu, Michal Valko, Rémi Munos. Efficient learning by implicit exploration in bandit problems with side observations. Neural Information Processing Systems, Dec 2014, Montréal, Canada. ⟨hal-01079351v2⟩
447 Consultations
305 Téléchargements
