Adaptation for the Masses: Towards Decentralized Adaptation in Large-Scale P2P Recommenders - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Decentralized recommenders have been proposed to deliver privacy-preserving, personalized and highly scalable on-line recommendation services. Current implementations tend, however, to rely on hard-wired, mechanisms that cannot adapt. Deciding beforehand which hard-wired mechanism to use can be difficult, as the optimal choice might depend on conditions that are unknown at design time. In this pa-per, propose a framework to develop dynamically adaptive decentralized recommendation systems. Our proposal sup-ports a decentralized form of adaptation, in which individual nodes can independently select, and update their own rec-ommendation algorithm, while still collectively contributing to the overall system's services.
similitude-main.pdf (832.48 Ko) Télécharger le fichier
hal-01080030 , version 1 (04-11-2014)
Copyright (Tous droits réservés)
Davide Frey, Anne-Marie Kermarrec, Christopher Maddock, Andreas Mauthe, François Taïani. Adaptation for the Masses: Towards Decentralized Adaptation in Large-Scale P2P Recommenders. Workshop on Adaptive and Reflective Middleware ARM 2014, Dec 2014, Bordeaux, France. ⟨10.1145/2677017.2677021⟩. ⟨hal-01080030⟩
285 Consultations
257 Téléchargements
