Preprints, Working Papers, ...
Motion Corrected 3D Liver undersampled MRI
Abstract : The emergence of sparse reconstruction methods for undersampled data in Magnetic Resonance Imaging (MRI), such as Compressed Sensing (CS), have been valuable tools to accelerate data acquisition while preserving accurate image reconstruction. However, sparse reconstruction methods, including CS, are not easy to apply when there is intra-frame motion. Such is the case of free-breathing dynamic MRI in the liver. It is difficult to avoid non-rigid motion artifacts, even more so in volumetric acquisitions. To avoid these kind of artifacts, we propose a new reconstruction technique tailored for dynamic liver imaging by estimating the motion between frames to correct inconsistencies in k-space measurements. In this work, we describe how the proposed method addresses an increase in image efficiency for free-breathing dynamic 3D liver MRI, producing gains up to 6 dB with respect of traditional CS framework. Our technique can be readily extended to 3D CINE liver MRI without requiring additional information.
Document type :
Complete list of metadata
Cited literature [28 references]  Display  Hide  Download
https://hal.inria.fr/hal-01080892
Contributor : Felipe Yanez <>
Submitted on : Monday, June 1, 2015 - 9:39:22 AM
Last modification on : Monday, June 1, 2015 - 10:47:40 AM
Long-term archiving on: : Monday, April 24, 2017 - 7:42:34 PM
File
3dLiver.pdf
Identifiers
  • HAL Id : hal-01080892, version 2
Citation
Felipe Yanez, Pablo Irarrazaval. Motion Corrected 3D Liver undersampled MRI. 2014. ⟨hal-01080892v2⟩
Share
Metrics
Record views
90
Files downloads
119
