Whole-genome re-sequencing of non-model organisms: lessons from unmapped reads - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Heredity Année : 2015
Unmapped reads are often discarded from the analysis of whole-genome re-sequencing, but new biological information and insights can be uncovered through their analysis. In this paper, we investigate unmapped reads from the re-sequencing data of 33 pea aphid genomes from individuals specialized on different host plants. The unmapped reads for each individual were retrieved following mapping to the Acyrthosiphon pisum reference genome and its mitochondrial and symbiont genomes. These sets of unmapped reads were then cross-compared, revealing that a significant number of these unmapped sequences were conserved across individuals. Interestingly, sequences were most commonly shared between individuals adapted to the same host plant, suggesting that these sequences may contribute to the divergence between host plant specialized biotypes. Analysis of the contigs obtained from assembling the unmapped reads pooled by biotype allowed us to recover some divergent genomic regions previously excluded from analysis and to discover putative novel sequences of A. pisum and its symbionts. In conclusion, this study emphasizes the interest of the unmapped component of re-sequencing data sets and the potential loss of important information. We here propose strategies to aid the capture and interpretation of this information.Heredity advance online publication, 1 October 2014; doi:10.1038/hdy.2014.85.
Heredity_Gouin_preprint.pdf (761.73 Ko) Télécharger le fichier
hal-01081094 , version 1 (06-11-2014)
Anaïs Gouin, Fabrice Legeai, Pierre Nouhaud, Annabel Whibley, Jean-Christophe Simon, et al.. Whole-genome re-sequencing of non-model organisms: lessons from unmapped reads. Heredity, 2015, 114, pp.494-501. ⟨10.1038/hdy.2014.85⟩. ⟨hal-01081094⟩
573 Consultations
266 Téléchargements
