Towards Modelling and Analysing Non-Functional Properties of Systems of Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Systems of systems (SoS) are large-scale systems composed of complex systems with difficult to predict emergent properties. One of the most significant challenges in the engineering of such systems if how to predict their Non-Functional Properties (NFP) such as performance and security, and more specifically, how to model NFP when the overall system functionality is not available. In this paper, we identify, describe and analyse challenges to modelling and analysing the performance and security NFP of SoS. We define an architectural framework to SoS NFP prediction based on the modelling of system interactions and their impacts. We adopt an Event Driven Architecture to support this modelling, as it allows for more realistic and flexible NFP simulation, which enables more accurate NFP prediction. A framework integrating the analysis of several NFP allows for exploring the impacts of changes made to accommodate issues on one NFP on other NFPs.
1569929417.pdf (673.07 Ko) Télécharger le fichier
hal-01082408 , version 1 (20-01-2020)
  • HAL Id : hal-01082408 , version 1
Vanea Chiprianov, Katrina Falkner, Laurent Gallon, Manuel Munier. Towards Modelling and Analysing Non-Functional Properties of Systems of Systems. IEEE 9th International System of Systems Engineering Conference (SoSE'2014), Jun 2014, Stamford Grand, Adelaide, Australia. pp.289-294. ⟨hal-01082408⟩
Collections
UNIV-PAU LIUPPA
54 Consultations
77 Téléchargements
