Semantic Mashup with the Online IDE WikiNEXT
The proposed demonstration requests DBPedia.org, gets the results and uses them to populate wiki pages with semantic annotations using RDFaLite. These annotations are persisted in a RDF store and we will show how this data can be reused by other applications, e.g. for a semantic mashup that displays all collected metadata about cities on a single map page. It has been developed using WikiNEXT, a mix between a semantic wiki and a web-based IDE. The tool is online 1 , open source 2 ; screencasts are available on YouTube (look for "WikiNext").
Informatique [cs]
