Journal articles
Reference-free detection of isolated SNPs
Raluca Uricaru 1, 2, 3, 4, * Guillaume Rizk 4 Vincent Lacroix 5, 6 Elsa Quillery 7, 8 Olivier Plantard 8, 7 Rayan Chikhi 9 Claire Lemaitre 4, * Pierre Peterlongo 4, *
* Corresponding author
4 GenScale - Scalable, Optimized and Parallel Algorithms for Genomics
Inria Rennes – Bretagne Atlantique , IRISA-D7 - GESTION DES DONNÉES ET DE LA CONNAISSANCE
5 Baobab
PEGASE - Département PEGASE [LBBE]
6 BAMBOO - An algorithmic view on genomes, cells, and environments
Inria Grenoble - Rhône-Alpes, LBBE - Laboratoire de Biométrie et Biologie Evolutive - UMR 5558
7 UMR1300 Biology, Epidemiology and Risk Analysis in animal health
ONIRIS - École nationale vétérinaire, agroalimentaire et de l'alimentation Nantes-Atlantique
Abstract : Detecting Single Nucleotide Polymorphisms (SNPs) between genomes is becoming a routine task with Next Generation Sequencing. Generally, SNP detection methods use a reference genome. As non-model organisms are increasingly investigated, the need for reference-free methods has been amplified. Most of the existing reference-free methods have fundamental limitations: they can only call SNPs between exactly two datasets, and/or they require a prohibitive amount of computational resources. The method we propose, DISCOSNP, detects both heterozygous and homozygous isolated SNPs from any number of read datasets, without a reference genome, and with very low memory and time footprints (billions of reads can be analyzed with a standard desktop computer). To facilitate downstream genotyping analyses, DISCOSNP ranks predictions and outputs quality and coverage per allele. Compared to finding isolated SNPs using a state-of-the-art assembly and mapping approach, DISCOSNP requires significantly less computational resources, shows similar precision/recall values, and highly ranked predictions are less likely to be false positives. An experimental validation was conducted on an arthropod species (the tick Ixodes ricinus) on which de novo sequencing was performed. Among the predicted SNPs that were tested, 96% were successfully genotyped and truly exhibited polymorphism.
Keywords : reference-free SNP NGS
Complete list of metadata
Cited literature [25 references]  Display  Hide  Download
https://hal.inria.fr/hal-01083715
Contributor : Pierre Peterlongo Connect in order to contact the contributor
Submitted on : Monday, December 1, 2014 - 9:45:58 AM
Last modification on : Saturday, June 25, 2022 - 10:35:23 AM
Long-term archiving on: : Friday, April 14, 2017 - 2:40:53 PM
discoSnp_NAR_2014.pdf
Distributed under a Creative Commons Attribution - NonCommercial 4.0 International License
Identifiers
Citation
Raluca Uricaru, Guillaume Rizk, Vincent Lacroix, Elsa Quillery, Olivier Plantard, et al.. Reference-free detection of isolated SNPs. Nucleic Acids Research, Oxford University Press, 2014, 43 (2), pp.e11. ⟨10.1093/nar/gku1187⟩. ⟨hal-01083715⟩
Share
Metrics
Record views
668
Files downloads
418
