MPTCP is not Pareto-Optimal: Performance Issues and a Possible Solution - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE/ACM Transactions on Networking Année : 2013
MPTCP has been proposed recently as a mechanism for transparently supporting multiple connections to the appli-cation layer. It is under discussion at the IETF. We nevertheless demonstrate that the current MPTCP suffers from two problems: (P1) Upgrading some TCP users to MPTCP can reduce the throughput of others without any benefit to the upgraded users, which is a symptom of not being Pareto-optimal; and (P2) MPTCP users could be excessively aggressive towards TCP users. We attribute these problems to the linked-increases algorithm (LIA) of MPTCP and, more specifically, to an excessive amount of traffic transmitted over congested paths. The design of LIA forces a tradeoff between optimal resource pooling and responsiveness. We revisit the problem and show that it is possible to provide these two properties simultaneously. We implement the resulting algorithm, called the opportunistic linked-increases algorithm (OLIA), in the Linux kernel, and we study its performance over our testbed, by simulations and by theoretical analysis. We prove that OLIA is Pareto-optimal and satisfies the design goals of MPTCP. Hence it can avoid the problems P1 and P2. Our measurements and simulations indicate that MPTCP with OLIA is as responsive and non-flappy as MPTCP with LIA and that it solves problems P1 and P2.
MPTCP_notParetoOptimal_ToN.pdf (1.32 Mo) Télécharger le fichier
hal-01086030 , version 1 (21-11-2014)
Ramin Khalili, Nicolas Gast, Miroslav Popovic, Jean-Yves Le Boudec. MPTCP is not Pareto-Optimal: Performance Issues and a Possible Solution. IEEE/ACM Transactions on Networking, 2013, pp.15. ⟨10.1109/TNET.2013.2274462⟩. ⟨hal-01086030⟩
1504 Consultations
1233 Téléchargements
