Short Paper: #SEVEN, a Sensor Effector Based Scenarios Model for Driving Collaborative Virtual Environment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we present #SEVEN, a sensor effector model that enables the execution of complex scenarios for driving Virtual Reality applications. #SEVEN is based on an enhanced Petri net model which is able to describe and solve intricate event sequences. Our model also proposes several useful features for the design of collaborative scenarios for Collaborative Virtual Environments such as versatile roles and Activity Continuum. We also illustrate its usage it by describing a demonstrator that presents an implementation of our model.
Mots clés
EGVE2014.pdf (152.9 Ko) Télécharger le fichier
hal-01086237 , version 1 (03-12-2014)
  • HAL Id : hal-01086237 , version 1
Guillaume Claude, Valérie Gouranton, Rozenn Bouville Berthelot, Bruno Arnaldi. Short Paper: #SEVEN, a Sensor Effector Based Scenarios Model for Driving Collaborative Virtual Environment. ICAT-EGVE, International Conference on Artificial Reality and Telexistence, Eurographics Symposium on Virtual Environments, Dec 2014, Bremen, Germany. pp.1-4. ⟨hal-01086237⟩
869 Consultations
433 Téléchargements
