Abstract : Developing concurrent systems typically involves a lengthy debugging period, due to the huge number of possible intricate behaviors. Using a high level description formalism at the intermediate level between the specification and the code can vastly help reduce the cost of this process, and the existence of remaining bugs in the deployed code. Verification is much more affordable at this level. An automatic translation of component based systems into running code, which preserves the temporal properties of the design, helps synthesizing reliable code. We provide here a transformation from a high level description formalism of component based system with probabilistic choices into running code. This transformation involves synchronization using shared variables. This synchronization is component-based rather than interaction-based, because of the need to guarantee a stable view for a component that performs probabilistic choice. We provide the synchronization algorithm and report on the implementation.
https://hal.inria.fr/hal-01087664 Contributor : Uli FahrenbergConnect in order to contact the contributor Submitted on : Wednesday, November 26, 2014 - 2:41:58 PM Last modification on : Wednesday, February 2, 2022 - 3:50:58 PM Long-term archiving on: : Friday, February 27, 2015 - 12:20:37 PM
Saddek Bensalem, Axel Legay, Ayoub Nouri, Doron Peled. Synthesizing Distributed Scheduling Implementation for Probabilistic Component-based Systems. MEMOCODE, Oct 2013, Portland, United States. ⟨hal-01087664⟩
