Computing Semicommutation Closures: a Machine Learning Approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
Semicommutation relations are simple rewriting relation on finite words using rules of the form ab → ba. In this paper we present how to use Angluin style machine learning algorithms to compute the image of regular language by the transitive closure of a semicommutation relation.
mainLearning.pdf (168.4 Ko) Télécharger le fichier
hal-01087740 , version 1 (02-12-2014)
  • HAL Id : hal-01087740 , version 1
Maxime Bride, Pierre-Cyrille Héam, Isabelle Jacques. Computing Semicommutation Closures: a Machine Learning Approach. [Research Report] FEMTO-ST. 2014. ⟨hal-01087740⟩
200 Consultations
114 Téléchargements
