Translation Validation for Clock Transformations in a Synchronous Compiler
Translation validation was introduced as a technique to for-mally verify the correctness of code generators that attempts to verify that program transformations preserve the semantics. In this work, we adopt this approach to construct a validator that formally verifies the preservation of clock semantics during the Signal compiler transforma-tions. The clock semantics is represented as a first-order logic formula called clock model. Then we introduce a refinement relation which ex-presses the preservation of clock semantics, as a relation on clock models. Our validator does not require any instrumentation or modification of the compiler, nor any rewriting of the source program.
main.pdf (385.78 Ko)
Télécharger le fichier
main (1).pdf (385.78 Ko)
