Parallel biological in silico simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
It is crucial to understand how biological systems work, in particular the metabolic pathways, if we want to be able to understand diseases. For instance, why and how the apoptosis mechanisms are disturbed in some cancers. One of the author has developed HSIM, a simulator dedicated to the biochemical simulation of the reactions inside the compartments of a virtual cell. Another author is the leader in the development of BOBPP a high level parallelization framework. In this article, we propose an important improvement of BOBPP in order to run HSIM in parallel. This will allow us to simulate more complex models, involving more chemical species and reactions, leading to more realistic results using a smaller amount of computing time.
Fichier non déposé
hal-01087811 , version 1 (26-11-2014)
Patrick Amar, Muriel Baillieul, Dominique Barth, Bertrand Lecun, Franck Quessette, et al.. Parallel biological in silico simulation. 29th Intenational Symposium on Computer and Information Sciences, Oct 2014, Krakow, Poland. pp.387-394, ⟨10.1007/978-3-319-09465-6_40⟩. ⟨hal-01087811⟩
194 Consultations
0 Téléchargements
