Statistical model checking QoS properties of systems with SBIP - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal on Software Tools for Technology Transfer Année : 2014
Ayoub Nouri
  • Fonction : Auteur
Saddek Bensalem
Marius Bozga
Benoit Delahaye
BIP is a component-based framework sup-porting rigorous design of embedded systems. BIP sup-ports incremental design of large systems from atomic components that communicates via connectors and whose interactions can be described with a powerful algebra. This paper presents SBIP, an extension of BIP for stochastic systems. SBIP offers the possibility to add stochastic information to atomic component's behaviors, and hence to the entire system. Atomic component's semantics in SBIP is described by Markov Chains. We show that the semantics of the entire system is described by a Markov chain, showing that the non-determinism arising from system interac-tions is automatically eliminated by BIP. This allows us to verify systems described in SBIP with Statistical Model Checking. This paper introduces SBIP and illustrates its usabil-ity on several industrial case studies.
main.pdf (750.69 Ko) Télécharger le fichier
hal-01087822 , version 1 (26-11-2014)
Ayoub Nouri, Saddek Bensalem, Marius Bozga, Benoit Delahaye, Cyrille Jegourel, et al.. Statistical model checking QoS properties of systems with SBIP. International Journal on Software Tools for Technology Transfer, 2014, pp.14. ⟨10.1007/s10009-014-0313-6⟩. ⟨hal-01087822⟩
501 Consultations
394 Téléchargements
