Construction Interval Observers for Continuous-Time Systems with Discrete Measurements - Archive ouverte HAL Access content directly
Journal Articles Automatica Year : 2014
We consider continuous-time systems with input, output and additive disturbances in the particular case where the measurements are only available at discrete instants and have disturbances. To solve a state estimation problem, we construct continuous–discrete interval observers that are asymptotically stable in the absence of disturbances. These interval observers are composed of two copies of the studied system and of a framer, accompanied with appropriate outputs which give, componentwise, upper and lower bounds for the solutions of the studied system.
Not file
Dates and versions
hal-01088128 , version 1 (27-11-2014)
Identifiers
Cite
Frédéric Mazenc, Thach Ngoc Dinh. Construction Interval Observers for Continuous-Time Systems with Discrete Measurements. Automatica, 2014, 50 (10), pp.2555-2560. ⟨10.1016/j.automatica.2014.08.008⟩. ⟨hal-01088128⟩
116 View
0 Download
Share
