Visual perception of unitary elements for layout analysis of unconstrained documents in heterogeneous databases - Archive ouverte HAL Access content directly
Conference Papers Year :
(1, 2) , (3, 1) , (1, 2)
1
2
3
The document layout analysis is a complex task in the context of heterogeneous documents. It is still a challenging problem. In this paper, we present our contribution for the layout analysis competition of the international Maurdor Cam-paign. Our method is based on a grammatical description of the content of elements. It consists in iteratively finding and then removing the most structuring elements of documents. This method is based on notions of perceptive vision: a combination of points of view of the document, and the analysis of salient contents. Our description is generic enough to deal with a very wide range of heterogeneous documents. This method obtained the second place in Run 2 of Maurdor Campaign (on 1000 documents), and the best results in terms of pixel labeling for text blocs and graphic regions.
PID3215629.pdf (2.79 Mo) Télécharger le fichier
Dates and versions
hal-01088807 , version 1 (28-11-2014)
Identifiers
  • HAL Id : hal-01088807 , version 1
Cite
Baptiste Poirriez, Aurélie Lemaitre, Bertrand Coüasnon. Visual perception of unitary elements for layout analysis of unconstrained documents in heterogeneous databases. 14th International Conference on Frontiers in Handwriting Recognition (ICFHR-2014), Sep 2014, Crete island, Greece. ⟨hal-01088807⟩
337 View
151 Download
Share
