Design Flow and Run-Time Management for Compressed FPGA Configurations - Archive ouverte HAL Access content directly
Conference Papers Year : 2015
The aim of partially and dynamically reconfigurable hardware is to provide an increased flexibility through the load of multiple applications on the same reconfigurable fabric at the same time. However, a configuration bit-stream loaded at runtime should be created offline for each task of the application. Moreover, modern applications use a lot of specialized hardware blocks to perform complex operations, which tends to cancel the "single bit-stream for a single application" paradigm, as the logic content for different locations of the reconfigurable fabric may be different. In this paper we propose a design flow for generating compressed configuration bit-streams abstracted from their final position on the logic fabric. Those configurations will then be decoded and finalized in real-time and at run-time by a dedicated reconfiguration controller to be placed at a given physical location. Our experiments show that densely routed applications gain the most with a compression factor of more than 2× using the finest cluster size, but coarser coding can be implemented to achieve a compression factor up to 10×.
huriaux-date15.pdf (221.96 Ko) Télécharger le fichier
Dates and versions
hal-01089319 , version 1 (01-12-2014)
Identifiers
  • HAL Id : hal-01089319 , version 1
Cite
Christophe Huriaux, Antoine Courtay, Olivier Sentieys. Design Flow and Run-Time Management for Compressed FPGA Configurations. DATE - Design, Automation and Test in Europe, Mar 2015, Grenoble, France. ⟨hal-01089319⟩
384 View
302 Download
Share
