Tetrys, an On-the-Fly Network Coding protocol - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Autre Publication Année : 2015
This document describes Tetrys, an On-The-Fly Network Coding (NC) protocol which can be used to transport delay and loss sensitive data over a network. This protocol can be used for unicast, multicast or anycast communications. It recovers lost packets by using added coded packets. Tetrys allows to recover all missing data within a time independent of the RTT and does not rely on a reliable feedback path to transmit data.
draft-detchart-nwcrg-tetrys-02.pdf (51.88 Ko) Télécharger le fichier
hal-01089745 , version 1 (02-12-2014)
hal-01089745 , version 2 (16-03-2015)
hal-01089745 , version 3 (19-07-2015)
  • HAL Id : hal-01089745 , version 3
Jonathan Detchart, Emmanuel Lochin, Jérôme Lacan, Vincent Roca. Tetrys, an On-the-Fly Network Coding protocol. 2015. ⟨hal-01089745v3⟩
257 Consultations
331 Téléchargements
