Reports
On the complexity of the representation of simplicial complexes by trees
Jean-Daniel Boissonnat 1 Dorian Mazauric 1
1 GEOMETRICA - Geometric computing
CRISAM - Inria Sophia Antipolis - Méditerranée , Inria Saclay - Ile de France
Abstract : In this paper, we investigate the problem of the representation of simplicial complexes by trees. We introduce and analyze local and global tree representations. We prove that the global tree representation is more ecient in terms of time complexity for searching a given simplex and we show that the local tree representation is more ecient in terms of size of the structure. The simplicial complexes are modeled by hypergraphs. We then prove that the associated combinatorial optimization problems are very dicult to solve and to approximate even if the set of maximal simplices induces a cubic graph, a planar graph, or a bounded degree hypergraph. However, we prove polynomial time algorithms that compute constant factor approximations and optimal solutions for some classes of instances.
Complete list of metadata
Cited literature [8 references]  Display  Hide  Download
https://hal.inria.fr/hal-01089846
Contributor : Dorian Mazauric Connect in order to contact the contributor
Submitted on : Friday, September 4, 2015 - 4:36:18 PM
Last modification on : Saturday, May 1, 2021 - 3:38:28 AM
Long-term archiving on: : Saturday, December 5, 2015 - 12:36:02 PM
File
RR-8647.pdf
Identifiers
  • HAL Id : hal-01089846, version 2
Citation
Jean-Daniel Boissonnat, Dorian Mazauric. On the complexity of the representation of simplicial complexes by trees. [Research Report] RR-8647, Inria Sophia Antipolis; INRIA. 2014. ⟨hal-01089846v2⟩
Share
Metrics
Les métriques sont temporairement indisponibles
