De-anonymization attack on geolocated data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computer and System Sciences Année : 2014
With the advent of GPS-equipped devices, a massive amount of location data is being collected, raising the issue of the privacy risks incurred by the individuals whose movements are recorded. In this work, we focus on a specific inference attack called the de-anonymization attack, by which an adversary tries to infer the identity of a particular individual behind a set of mobility traces. More specifically, we propose an implementation of this attack based on a mobility model called Mobility Markov Chain (MMC). A MMC is built out from the mobility traces observed during the training phase and is used to perform the attack during the testing phase. We design several distance metrics quantifying the closeness between two MMCs and combine these distances to build de-anonymizers that can re-identify users in an anonymized geolocated dataset. Experiments conducted on real datasets demonstrate that the attack is both accurate and resilient to sanitization mechanisms such as downsampling.
deanonymization_journal.pdf (834.65 Ko) Télécharger le fichier
hal-01242268 , version 1 (11-12-2015)
Sébastien Gambs, Marc-Olivier Killijian, Miguel Nuñez del Prado Cortez. De-anonymization attack on geolocated data. Journal of Computer and System Sciences, 2014, 80 (8), pp.1597-1614. ⟨10.1016/j.jcss.2014.04.024⟩. ⟨hal-01242268⟩
460 Consultations
1033 Téléchargements
