Adaptive Hand-Tracked System for 3D Authoring - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present the interaction design and the component architecture of an adaptive \ authoring system based on a consumer-range 3D input device. We claim that this \ system can help both novice and experienced users performing authoring tasks in \ a 3D authoring environment. The system uses a keyboardless \ self-adaptive interaction controller built upon a rule-based system that learns \ and infers the user's behavior/condition on the fly according to her actions; \ rearranging rules when necessary and suggesting breaks to avoid performance \ drops caused by fatigue or the so-called gorilla-arm effect. \
p101-heloir.pdf (256.93 Ko) Télécharger le fichier
hal-01090421 , version 1 (03-12-2014)
  • HAL Id : hal-01090421 , version 1
Alexis Heloir, Fabrizio Nunnari, Christophe Kolski. Adaptive Hand-Tracked System for 3D Authoring. IHM'14, 26e conférence francophone sur l'Interaction Homme-Machine, Oct 2014, Villeneuve D'Ascq, France. pp.101-104. ⟨hal-01090421⟩
102 Consultations
173 Téléchargements
