Formal Models and Techniques for Analyzing Security Protocols: A Tutorial - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Foundations and Trends in Programming Languages Année : 2014
Security protocols are distributed programs that aim at securing communications by the means of cryptography. They are for instance used to secure electronic payments, home banking and more recently electronic elections. Given The financial and societal impact in case of failure, and the long history of design flaws in such protocol, formal verification is a necessity. A major difference from other safety critical systems is that the properties of security protocols must hold in the presence of an arbitrary adversary. The aim of this paper is to provide a tutorial to some modern approaches for formally modeling protocols, their goals and automatically verifying them.
CK-fntpl-14.pdf (761.47 Ko) Télécharger le fichier
hal-01090874 , version 1 (13-10-2015)
Véronique Cortier, Steve Kremer. Formal Models and Techniques for Analyzing Security Protocols: A Tutorial. Foundations and Trends in Programming Languages, 2014, 1 (3), pp.117. ⟨10.1561/2500000001⟩. ⟨hal-01090874⟩
630 Consultations
2346 Téléchargements
