New interface
Journal articles
Aeolus: a Component Model for the Cloud
Roberto Di Cosmo 1 Jacopo Mauro 2, 3 Stefano Zacchiroli 1 Gianluigi Zavattaro 2, 3
2 FOCUS - Foundations of Component-based Ubiquitous Systems
CRISAM - Inria Sophia Antipolis - Méditerranée , DISI - Dipartimento di Informatica - Scienza e Ingegneria [Bologna]
Abstract : We introduce the Aeolus component model, which is specifically designed to capture realistic scenarii arising when configuring and deploying distributed applications in the so-called cloud environments, where interconnected components can be deployed on clusters of heterogeneous virtual machines, which can be in turn created, destroyed, and connected on-the-fly. The full Aeolus model is able to describe several component characteristics such as dependencies, conflicts, non-functional requirements (replication requests and load limits), as well as the fact that component interfaces to the world might vary depending on the internal component state. When the number of components needed to build an application grows, it becomes important to be able to automate activities such as deployment and reconfiguration. This correspond, at the level of the model, to the ability to decide whether a desired target system configuration is reachable, which we call the achievability problem, and producing a path to reach it. In this work we show that the achievability problem is undecidable for the full Aeolus model, a strong limiting result for automated configuration in the cloud. We also show that the problem becomes decidable, but Ackermann-hard, as soon as one drops non-functional requirements. Finally, we provide a polynomial time algorithm for the further restriction of the model where support for inter-component conflicts is also removed.
Document type :
Journal articles
Complete list of metadata
Cited literature [28 references]  Display  Hide  Download
https://hal.inria.fr/hal-01091062
Contributor : Jacopo Mauro Connect in order to contact the contributor
Submitted on : Thursday, December 4, 2014 - 3:28:09 PM
Last modification on : Saturday, June 25, 2022 - 7:43:55 PM
Long-term archiving on: : Monday, March 9, 2015 - 5:59:42 AM
File
main.pdf
Identifiers
  • HAL Id : hal-01091062, version 1
Collections
Citation
Roberto Di Cosmo, Jacopo Mauro, Stefano Zacchiroli, Gianluigi Zavattaro. Aeolus: a Component Model for the Cloud. Information and Computation, 2014, pp.100-121. ⟨hal-01091062⟩
Share
Metrics
Record views
374
Files downloads
314
