A Case for Multi-Switch Constraints in OPAM - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Package managers usually only deal with packages and their versions, and the con-straints on their dependencies towards other packages' versions. Among package man-agers, opam is probably the first one to introduce the notion of switch, i.e. the ability to manage different directories, where different sets of packages with different versions are installed, as each directory is treated as an independant universe when solving depen-dency constraints. In this talk, we will support a case to be able, in opam, to manage different switches in the same universe, allowing to express dependency constraints that cross switch boundaries.
ocaml2014_12.pdf (105.51 Ko) Télécharger le fichier
hal-01091175 , version 1 (08-12-2014)
  • HAL Id : hal-01091175 , version 1
Fabrice Le Fessant. A Case for Multi-Switch Constraints in OPAM. OCaml 2014, Sep 2014, goteborg, Sweden. ⟨hal-01091175⟩
Collections
INRIA INRIA2
74 Consultations
49 Téléchargements
