Automatic Generation of Correlation Rules to Detect Complex Attack Scenarios
In large distributed information systems, alert correlation systems are necessary to handle the huge amount of elementary security alerts and to identify complex multi-step attacks within the flow of low level events and alerts. In this paper, we show that, once a human expert has provided an action tree derived from an attack tree, a fully automated transformation process can generate exhaustive correlation rules that would be tedious and error prone to enumerate by hand. The transformation relies on a detailed description of various aspects of the real execution environment (topology of the system, deployed services, etc.). Consequently, the generated correlation rules are tightly linked to the characteristics of the monitored information system. The proposed transformation process has been implemented in a prototype that generates correlation rules expressed in an attack description language.
