Enforcing Privacy in Decentralized Mobile Social Networks - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This position paper first summarizes work done by the first author on location privacy and differential privacy. These techniques will help to solve privacy problems in decentralized mobile social networks, which is the main theme of his PhD research. The paper then briefly reviews the state-of-the-art in privacy-preservation of social graphs and clarifies the lack of attention to graph sharing in decentralized setting. Finally, some initial ideas on how to realize such soft decentralized access controls are described.
essos-phd.pdf (101.98 Ko) Télécharger le fichier
hal-01092447 , version 1 (08-12-2014)
  • HAL Id : hal-01092447 , version 1
Huu Hiep Nguyen, Abdessamad Imine, Michael Rusinowitch. Enforcing Privacy in Decentralized Mobile Social Networks. ESSoS Doctoral Symposium 2014, Feb 2014, Munich, Germany. ⟨hal-01092447⟩
157 Consultations
132 Téléchargements
