Does Boson Sampling need Fault-Tolerance? - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2014
BosonSampling is a problem where a quantum computer offers a provable speedup over classical computers. Its main feature is that it can be solved with current linear optics technology, without the need for a full quantum computer. In this work, we investigate whether an experimentally realistic BosonSampler can really solve BosonSampling without any fault-tolerance mechanism. More precisely, we study how the unavoidable errors linked to an imperfect calibration of the optical elements affect the final result of the computation. We show that the fidelity of each optical element must be at least 1−O(1/n2), where n refers to the number of single photons in the scheme. Such a requirement seems to be achievable with state-of-the-art equipment.
poster-Leverrier-final.pdf (1.77 Mo) Télécharger le fichier
hal-01094201 , version 1 (11-12-2014)
  • HAL Id : hal-01094201 , version 1
Anthony Leverrier, Raul Garcia-Patron. Does Boson Sampling need Fault-Tolerance?. Quantum Information Processing - QIP 2014, Feb 2014, Barcelone, Spain. . ⟨hal-01094201⟩
Collections
INRIA INRIA2
78 Consultations
32 Téléchargements
