Attractor computation using interconnected Boolean networks: testing growth rate models in E. Coli - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theoretical Computer Science Année : 2014
Alfonso Carta
  • Fonction : Auteur
  • PersonId : 772829
  • IdRef : 178847631
Boolean networks provide a useful tool to address questions on the structure of large biochemical interactions since they do not require kinetic details and, in addition, a wide range of computational tools and algorithms is available to exactly compute and study the dynamical properties of these models. A recently developed method has shown that the attractors, or asymptotic behavior, of an asynchronous Boolean network can be computed at a much lower cost if the network is written as an interconnection of two smaller modules. We have applied this methodology to study the interconnection of two Boolean models to explore bacterial growth and its interactions with the cellular gene expression machinery, with a focus on growth dynamics as a function of ribosomes, RNA polymerase and other "bulk" proteins inside the cell. The discrete framework permits easier testing of different combinations of biochemical interactions, leading to hypotheses elimination and model discrimination, and thus providing useful insights for the construction of a more detailed dynamical growth model.
ecoli-bool-web-version-final.pdf (591.35 Ko) Télécharger le fichier
hal-01095196 , version 1 (15-12-2014)
Madalena Chaves, Alfonso Carta. Attractor computation using interconnected Boolean networks: testing growth rate models in E. Coli. Theoretical Computer Science, 2014, pp.17. ⟨10.1016/j.tcs.2014.06.021⟩. ⟨hal-01095196⟩
177 Consultations
163 Téléchargements
