Feature-based terrain editing from complex sketches
We present a new method for first person sketch-based editing of terrain models. As in usual artistic pictures, the input sketch
depicts complex silhouettes with cusps and T-junctions, which typically correspond to non-planar curves in 3D. After analysing
depth constraints in the sketch based on perceptual cues, our method best matches the sketched silhouettes with silhouettes or ridges
of the input terrain. A deformation algorithm is then applied to the terrain, enabling it to exactly match the sketch from the given
perspective view, while insuring that none of the user-defined silhouettes is hidden by another part of the terrain. We extend this
sketch-based terrain editing framework to handle a collection of multi-view sketches. As our results show, this method enables
users to easily personalize an existing terrain, while preserving its plausibility and style.
Domains
Graphics [cs.GR]
PECHD-CG14.pdf (22.29 Mo)
Télécharger le fichier
Format : Figure, Image
