Learning Subgraph Patterns from text for Extracting Disease–Symptom Relationships - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mohsen Hassan
  • Fonction : Auteur
  • PersonId : 772857
  • IdRef : 204077710
Adrien Coulet
Yannick Toussaint
To some extent, texts can be represented in the form of graphs, such as dependency graphs in which nodes represent words and edges represent grammatical dependencies between words. Graph representation of texts is an interesting alternative to string representation because it provides an additional level of abstraction over the syntax that is sometime easier to compute. In this paper, we study the use of graph mining methods on texts represented as dependency graphs, for extracting relationships between pairs of annotated entities. We propose a three step approach that includes (1) the transformation of texts in a collection of dependency graphs; (2) the selection of frequent subgraphs, named hereafter patterns, on the basis of positive sentences; and (3) the extraction of relationships by searching for occurrences of patterns in novel sentences. Our method has been experimented by extracting disease–symptom relationships from a corpus of 51,292 PubMed abstracts (428,491 sentences)related to 50 rare diseases. The extraction of correct disease–symptom relationships has been evaluated on 565 sentences, showing a precision of 0.91 and a recall of 0.49 (F-Meaure is 0.63). These preliminary experiments show the feasibility of extracting good quality relationships using frequent subgraph mining.
paper6.pdf (1.32 Mo) Télécharger le fichier
hal-01095595 , version 1 (15-12-2014)
  • HAL Id : hal-01095595 , version 1
Mohsen Hassan, Adrien Coulet, Yannick Toussaint. Learning Subgraph Patterns from text for Extracting Disease–Symptom Relationships. 1st International Workshop on Interactions between Data Mining and Natural Language Processing, Sep 2014, Nancy, France. ⟨hal-01095595⟩
246 Consultations
432 Téléchargements
