The colorimetric assay of viability for algae (CAVA): a fast and accurate technique - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Applied Phycology Année : 2015
Determining the fraction of viable cells in algal cultures is critical to improve the understanding and control of algal microbiology, ecology, and biotechnology. Whereas current techniques for algal viability determination can be rather cumbersome, this paper describes a new assay that enables the rapid quantification of algal viability using only spectrophotometric measurements. This technique, henceforth named CAVA test, relies on the selective adsorption of erythrosine by non-viable cells and was validated on the algal species Chlamydomonas reinhardtii and Chlorella vulgaris. The results obtained by the CAVA test were in good agreement with the in situ measurement of oxygen production rates. In addition, the CAVA test was shown to quantify the viability of algal samples regardless of the cause of death (heating, UV-irradiation or H2O2 exposure). The CAVA technique has28 therefore the potential to offer fast and universal approach to measure the viability of algal samples.
JAPH-D-14-00456 for HAL.pdf (4.36 Mo) Télécharger le fichier
hal-01096355 , version 1 (17-12-2014)
Paternité
Quentin Béchet, Ivan Feurgard, Benoit Guieysse, Filipa Lopes. The colorimetric assay of viability for algae (CAVA): a fast and accurate technique. Journal of Applied Phycology, 2015, 27 (6), pp.2289-2297. ⟨10.1007/s10811-014-0508-y⟩. ⟨hal-01096355⟩
505 Consultations
1788 Téléchargements
