A Large Deviation Principle and an Expression of the Rate Function for a Discrete Stationary Gaussian Process - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Entropy Année : 2014
We prove a Large Deviation Principle for a stationary Gaussian process over R b , indexed by Z d (for some positive integers d and b), with positive definite spectral density and provide an expression of the corresponding rate function in terms of the mean of the process and its spectral density. This result is useful in applications where such an expression is needed.
GaussianLDPRuleGenaccepted.pdf (324.79 Ko) Télécharger le fichier
hal-01096758 , version 1 (18-12-2014)
Olivier Faugeras, James Maclaurin. A Large Deviation Principle and an Expression of the Rate Function for a Discrete Stationary Gaussian Process. Entropy, 2014, pp.21. ⟨10.3390/e16126722⟩. ⟨hal-01096758⟩
142 Consultations
180 Téléchargements
