Phytoplankton plasticity drives large variability in carbon fixation efficiency - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Geophysical Research Letters Année : 2014
Phytoplankton C:N stoichiometry is highly flexible due to physiological plasticity, which could lead to high variations in carbon fixation efficiency (carbon consumption relative to nitrogen). However, the magnitude, as well as the spatial and temporal scales of variability, remains poorly constrained. We used a high-resolution biogeochemical model resolving various scales from small to high, spatially and temporally, in order to quantify and better understand this variability. We find that phytoplankton C:N ratio is highly variable at all spatial and temporal scales (5-12 molC/molN), from mesoscale to regional scale, and is mainly driven by nitrogen supply. Carbon fixation efficiency varies accordingly at all scales (±30%), with higher values under oligotrophic conditions and lower values under eutrophic conditions. Hence, phytoplankton plasticity may act as a buffer by attenuating carbon sequestration variability. Our results have implications for in situ estimations of C:N ratios and for future predictions under high CO 2 world.
Ayata-et-al_2014_GRL_ppk_ratio.pdf (1.71 Mo) Télécharger le fichier
hal-01996384 , version 1 (28-01-2019)
Sakina-Dorothée Ayata, Marina Lévy, Olivier Aumont, Laure Resplandy, Alessandro Tagliabue, et al.. Phytoplankton plasticity drives large variability in carbon fixation efficiency. Geophysical Research Letters, 2014, 41 (24), pp.8994-9000. ⟨10.1002/2014gl062249⟩. ⟨hal-01996384⟩
514 Consultations
187 Téléchargements
