Preprints, Working Papers, ...
Objects and subtyping in the λΠ-calculus modulo
Abstract : We present a shallow embedding of the Object Calculus of Abadi and Cardelli in the λΠ-calculus modulo, an extension of the λΠ-calculus in which conversion is considered modulo a rewrite system. This embedding may be used as an example of translation of subtyping, a feature also present in some proof assistants like Coq and PVS. This embedding is proved correct with respect to the operational semantics and the type system of the Object Calculus. It has been implemented as a translation tool from the Object Calculus to Dedukti, a type-checker for the λΠ-calculus modulo.
Document type :
Complete list of metadata
Cited literature [23 references]  Display  Hide  Download
https://hal.inria.fr/hal-01097444
Contributor : Raphaël Cauderlier Connect in order to contact the contributor
Submitted on : Saturday, June 13, 2015 - 3:38:33 PM
Last modification on : Monday, February 21, 2022 - 3:38:12 PM
Long-term archiving on: : Tuesday, April 25, 2017 - 7:47:08 AM
File
article_types.pdf
Identifiers
  • HAL Id : hal-01097444, version 2
Collections
Citation
Raphaël Cauderlier, Catherine Dubois. Objects and subtyping in the λΠ-calculus modulo. 2015. ⟨hal-01097444v2⟩
Share
Metrics
Record views
170
Files downloads
164
