Avoiding traceroute anomalies with Paris traceroute - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Traceroute is widely used, from the diagnosis of network problems to the assemblage of internet maps. However, there are a few serious problems with this tool, in particu-lar due to the presence of load balancing routers in the net-work. This paper describes a number of anomalies that arise in nearly all traceroute-based measurements. We categorize them as "loops", "cycles", and "diamonds". We provide a new publicly-available traceroute, called Paris traceroute, which controls packet header contents to obtain a more pre-cise picture of the actual routes that packets follow. This new tool allows us to find conclusive explanations for some of the anomalies, and to suggest possible causes for others.
imc095-friedman.pdf (134.48 Ko) Télécharger le fichier
hal-01097553 , version 1 (19-12-2014)
Brice Augustin, Xavier Cuvellier, Benjamin Orgogozo, Fabien Viger, Timur Friedman, et al.. Avoiding traceroute anomalies with Paris traceroute. IMC 2006 - 6th ACM Internet Measurement Conference, Oct 2006, Rio de Janeiro, Brazil. pp.153-158, ⟨10.1145/1177080.1177100⟩. ⟨hal-01097553⟩
424 Consultations
1135 Téléchargements
